Creates (and modifies) a group and its access rights.
| hex_group_name | Specifies the group name to add or modify. The value is to be supplied as a colon separated string of hex octets. |
| group_name | Specifies the group name to add or modify. The value is to be supplied in ASCII format. |
| sec-model | Specifies the security model to use. |
| snmpv1 | Specifies the SNMPv1 security model. |
| snmpv2c | Specifies the SNMPv2c security model. |
| usm | Specifies the SNMPv3 User-based Security Model (USM). |
| sec-level | Specifies the security level for the group. |
| noauth | Specifies no authentication (and implies no privacy) for the security level. |
| authnopriv | Specifies authentication and no privacy for the security level. |
| priv | Specifies authentication and privacy for the security level. |
| read-view | Specifies the read view name:hex_read_view_name—Specifies a hex value supplied as a colon separated string of hex octetsread_view_name—Specifies an ASCII value. |
| write-view | Specifies the write view name:hex_write_view_name—Specifies a hex value supplied as a colon separated string of hex octetswrite_view_name—Specifies an ASCII value. |
| notify-view | Specifies the notify view name:hex_notify_view_name—Specifies a hex value supplied as a colon separated string of hex octetsnotify_view_name—Specifies an ASCII value. |
| volatile | Specifies volatile storage. |
sec-model—USM
sec-level—noauth
read view name—defaultUserView
write view name— “”
notify view name—defaultNotifyView
non-volatile storage
Use this command to configure access rights for a group. All access groups are created with a unique default context, “”, as that is the only supported context.
Use more than one character when creating unique community strings and access group names.
The default groups defined are v1v2c_ro for security name v1v2c_ro, v1v2c_rw for security name v1v2c_rw, admin for security name admin, and initial for security names initial, initialmd5, initialsha, initialmd5Priv and initialshaPriv.
The default access defined are admin, initial, v1v2c_ro, v1v2c_rw, and v1v2cNotifyGroup.
In the following command, access for the group defaultROGroup is created with all the default values: security model usm, security level noauth, read view defaultUserView, no write view, notify view defaultNotifyView, and storage nonvolatile.
configure snmpv3 add access defaultROGroup
In the following command, access for the group defaultROGroup is created with the values: security model USM, security level authnopriv, read view defaultAdminView, write view defaultAdminView, notify view defaultAdminView, and storage nonvolatile.
configure snmpv3 add access defaultROGroup sec-model usm sec-level authnopriv read-view defaultAdminView write-view defaultAdminView notify-view defaultAdminView
The hex_read_view_name, hex_write_view_name, and hex_notify_view_name parameters were added in ExtremeXOS 11.0.
